DJI Osmo Action 5 Pro: improving stitch and Ball Follow / Camera Mount
Hi,
I’m using the dual-camera mount shared by @mohamedtahaguelzim in Mount for GoPros. With two DJI Osmo Action 5 Pro cameras, they fit fine without their protective cases, but they do not fit well when the cases are installed.
I’m struggling to get a seamless stitch from the two sources using the default settings with Ball Follow. Here are the videos:
The sources were recorded at 5500K with Auto ISO.
I’m considering designing another mount with one camera inverted, so both optical centers are level and the lenses are as close together as practical (photo below). I noticed a similar inverted-camera idea in this part of the mount discussion.
Could anyone suggest the best way to improve both the stitch and Ball Follow output?
In particular:
  • What lens separation, camera angle/toe-in, and overlap work best for the Action 5 Pro?
  • Does putting both optical centers on the same horizontal plane materially improve the stitch at normal field distances, or does it mainly help with close subjects/parallax?
  • Which Reco settings should I tune before Ball Follow—ROI, lookahead, overlap, calibration, smoothing, or anything else?
  • How precise must the time sync and starting trim be between the two recordings?
  • Would a reusable calibration/profile or manual control points for this fixed rig help?
I’d appreciate recommendations on the best order and values to try.
Thanks!
Hi! Have you tried a different solution? What’s your experience?
thanks!
