Many of you have reported export hangs at “opening encoder and decoders”. I have only been able to reproduce when stitching multiple chained files.
I have released v0.5.3-beta.1 that should contain a fix for that. For those that had the issue, could you please let me know if it is still happening? Thanks
I did a little test and the sitch its quite better and also I hadnt have any problems with exports. I saw new configurations that I have to learn because change a lot how the export is.
The export with field AI is much better than ball one. I feel that this update is a great step into the right way.
I hope that the stream tool will be avaible soon, but I know that it is so complex so I will help and wait patienly hahaha. Also would be fantastic to stitch some clips together, I have clips 30s long and would be great to stitch more than one at the same time.
I’m not a great test case but I can confirm I was getting the error on 0.5.2 when trying to stitch multiple files on left/right. I no longer get the error on 0.5.3-beta.1 when trying to stitch multiple files! However the processing range end value appears to be limited to the length of the first clip (at least in the GUI) so I still can’t actually generate longer videos?
I did have to disable lookahead on 0.5.3-beta.1 to avoid an immediate error that seems unrelated though (appears to be from insufficient GPU ram available for the lookahead buffer, based on the logs) so it isn’t a perfect test. Lookahead appears to be beyond the limits of the decade-old laptop GPU I’m using lmao. Will hopefully get a chance to test on more powerful hardware soon
Will fix the range issue asap. And regarding the RAM, someone has found the issue and I will disable the preview during export and it should give enough RAM even in old hardware.
It (mostly) works now! I was able to generate a two-segment video. I think the encoding might be a bit messed up post-chain though, once it got into the second file portion the stitched video lost audio and was slow to seek and/or failing to play entirely in the standard “windows movies & tv” video player. VLC was able to handle seeking/playing but still had no audio.
Also the lookahead worked for me now! Small error somewhere leading to minor math issues
But I was successfully able to run a 1.1s lookahead!
Ope may have found another issue, when I tried to export again with adjusted ai tracking settings it wouldn’t let me lookahead because there was 0.0gb of gpu ram available so something’s not releasing properly:
Now I had have more time to test 0.5.3 beta 2 and I could not be more happy with it. Finally I could stitch some clips together, IA detection is still improving and calibration is quite better.
Export time is faster than before with the idea of pausing the preview. I know that the app is under developing yet, but it is going into the right way. Moreover, I reckon that there some things like my rig altitude or app setting that are my bad, so I have to improve too.
I will share two videos, they are the same footage. First one AI follows the ball and in the other one is field mode.
Thank you. Very promising indeed. Maybe YoloS or X will give better tracking, especially for ball tracking. Eventually, we should build a community dataset and fine tune a ball tracking model. It is that way that I got the good looking footage in the Youtube videos I published few weeks ago with lookahead.
Calibration is not the best yet, can you tell me again please what phones do you use to film? And there was a bug in the old version that i fixed (I think it should already be in 0.5.3 beta.2) which is that when you recalibrate, it would not use the lens you assigned in “Lens Profile” in the right window.
Did you try that again?
Thanks a lot for the support and testing,
And btw I am doing good progress for live phone input. I hope I can release it very soon.
There is a 3D print file that has been posted to this forum that holds two phones similar to the Veo Go rig. There are two files that have different tilt angles to them. Check it out. It’s the only one I’ve found online so far.
Audio and seeking are both working across multiple segments with the gui now! However when I tried to run with the CLI (because my frame_all changes aren’t in the release version yet) I got an error with the tracking and it just created a static camera on the center of the field. Will try to reproduce soon and give more details
