New interface: clearer, with light and dark mode and hover explanations on the buttons.
YOLO training: besides RF-DETR you can now train YOLO26 models and compare them directly.
AMD on Windows: detection runs on AMD and Intel graphics cards. Since 0.31.0 Reco Trainer also trains on current Radeon cards (RX 7700 to 7900, RX 9060/9070), about 40 times faster than the CPU on an RX 7800 XT.
With the Augmentation Studio I’m starting the next step: better models with less labelling work. It turns your labelled footage into new training images with matching perspective and correct labels.
I’d love for you to experiment with it and share your results. To make a test meaningful:
At least 300 reviewed, labelled images, ideally 500. They should come from several recordings or venues, not a single video.
For a first test, 1,500 to 2,000 variations, roughly three to five times the number of real images.
Then compare “mixed” against “real images only” in the benchmark. That’s the only way to see whether the generated images actually help with your footage. It depends a lot on the material.
I’ve got at least 4 games on different fields I can get labeled. I think I currently have 6 full length games still recorded/saved. I’ve got to say the new keyboard hot keys are making this SO much easier as well as the “thin” small boxes. one the issues I am wondering about since all my videos are currently split into L and R videos, and are in chapters due to go pro format I end up with a LOT of really blank images IE, Goal, Goalkeeper 1-2 players and maybe a sideline referee. Also with only being able to go down to 20 or 4 images per game I end up with about 180 images for 1 game, if I do 20 images per video.
Do you have a “guide” of what you’d like me to do for the 2nd and 3rd steps? I’m not the most computer savvy fella.
Agree, the new ui labeling improvements are fantastic!
For the images that are mostly “empty”, I’ve been removing them from the training set because I assume they bring little value to the training. I might keep a few, but drop the majority.
Grabbing 300 images from a 15 minute file yields about 75 actual training images.
I’ll need to film more footage to test the augmentation feature. Do the images need to be fully labeled with all the classes?
12 violations caught while generating and made again.
278 labels were smaller than 1.5 px at the output size and were removed.
Real images: 267 training, 77 validation, 44 test."
all the Sample images look great, some are a bit hilariously sized mismatched for the players. where I’m dumb is how do I use these generated images to train my model?
Glad the samples look good! To use them in Reco Trainer:
Select the same working folder as your real footage (the project with your 267 / 77 / 44 real images).
Click Import dataset and choose the generator’s dataset/coco folder. The images are copied in; the original stays untouched.
Check the class list and open a few images to confirm the boxes line up.
Train as usual. Next to real video frames, imported images are used for training only. Validation and test stay your real images, so the quality numbers still show how the model does on real footage.
To see if it helps, train once with and once without the synthetic images and compare both on the same real clip with Compare two models. 1500 synthetic vs. 267 real is a lot, so a smaller share may work better.
The size mismatch on some players is expected: the figures are still procedural and not validated for realism.
This is an experiment. The idea is to get better results with little effort, and we don’t know yet whether it works. I would be glad to hear how it goes for you, with or without the synthetic images.
