The issue with your setup isn’t the off-center camera placement, but rather the large distance between the cameras. Have you considered placing two cameras close to each other near the stands, at a slight angle (either at your red or blue spot)? The view wouldn’t be perfectly centered, but the tracking might compensate for that.
As far as I understand, you can’t stitch footage from two cameras that are so far apart (relatively to the close scene) because their perspectives are too different. One camera sees a player from behind, while the other sees them from the front.
Would it be possible to mount two cameras in the stands, even without tripods? Even if some seats are visible, the tracking zoom could crop them out.
Do you specifically need fixed PoE cameras? Their image quality is often quite limited.
As fas as I know there are two challenges on top to the optics with the PoE Cameras that I found. One is to keep them in sync, I guess that is solvable, and the other the fps. As long as you do not have minimum 30fps constantly you will have no fun.
I might have another approach. Does recocam just do the tracking regardless of the camera position? I found an extensions which allows RecoCam to have just one feed. Could i rund multiple instances with just one feed and don’t care about the centre-line perspective?
box area left, box are right, behind goal cams. And have several AI-tracking feeds`?
i would then choose the feeds on my own and cast more like a TV feeling stream
You could do great things with OBS which is really cool and free.
Another approach might be a hack to reco.cam. My picture is far away form perfect but I guess you will understand it. Two Reco cams one per Beam and a software which detects the ball and decides if it leaves the sight in the direction of the other lets switch to it. This is doable but not there yet.
IF you want a fixed setup you might think of something like that.
I have asked claude for advice. There is a lot of room for improvement but it gives you at least an idea:
Proposal: 4K Camera System for the Football Pitch (4 Cameras)
Goal: Cover the whole pitch in 4K30 for live streaming, match analysis and video review. The cameras are mounted permanently and powered and connected through a single network cable each (PoE). A computer inside the clubhouse does the processing.
Setup:
2 existing masts along the touchline, 2 cameras on each
Mast 1 (left): one wide-angle camera (approx. 90°) for the goal area and penalty box, one camera with approx. 50° for the left-center area
Mast 2 (right): one camera with approx. 50° for the right-center area, one with approx. 70° for the goal area and penalty box
The images overlap slightly and are stitched into one view on the computer
All cameras have a fixed focal length and fixed position, no remote control needed
8-port PoE switch in the building (PoE budget of at least 60 W)
€150
$173
2 × outdoor enclosure with small PoE switch at the mast
€240
$276
Outdoor Cat6 network cable, UV-resistant, shielded (approx. 150 m)
€225
$259
Conduit, cable duct, fixings
€100
$115
Surge protection (4 units)
€80
$92
Small parts (connectors, seals, cable ties)
€50
$58
Subtotal
approx. €1,545
approx. $1,777
Contingency (approx. 15%)
approx. €230
approx. $265
Total
approx. €1,800
approx. $2,070
The processing computer and software are not included. Installation would be done by volunteers.
Open points:
Exact pitch dimensions, mast height and cable route to the clubhouse need to be measured on site. Lens focal lengths and cable length depend on them.
Data protection: signage at the pitch and approval from the board.
Do the masts need permission for mounting equipment?
Using DIY camera boards instead of ready-made cameras would cut about €400 (approx. $460). The trade-off is more effort and a higher risk of failures in outdoor use.
PS if you are really interested in building such a camera I would support you with a design proposal and a patch for reco.cam that solves the decision which camera should be live.
The housing is done, and the bill of materials follows below. I could not check live Amazon listings, because my search returned only Newegg and manufacturer pages. So there are no ASINs. The “Amazon search term” column is what to type in, and the prices are rough estimates from the pages I did find.
Housing (for one camera)
I designed it around a 38 × 38 mm IMX415 IP-camera board stack with an M12 lens, as in the A8MM8S-type modules.
Body: a tube with a 58 mm bore and 8 mm walls. It has a flat pad underneath for a 1/4"-20 mount insert.
Front ring: holds a 62 × 2 mm clear window disc.
Rear cap: has a hole for a PG13.5 cable gland, a hole for an M12 breather vent, and four posts for the boards.
Sun hood: a collar with a tapered hood. It is sized from the lens field of view so it blocks stray sun without vignetting. For the 70° lens it starts blocking light above about 28° off the lens axis. The picture’s vertical half-angle is 21.5°, so there is some margin. The underside is open so water can drain.
All four parts are watertight and don’t overlap each other. I have not printed or test-fitted them.
Print notes
Use ASA in black, or PETG if you can’t get ASA. Use 4–5 perimeters.
Print the body standing up, with supports only under the mounting pad.
Check before printing
Board holes: The board holes are assumed to be 32 × 32 mm. Change POST_XY in build.py to match your board.
Lens:HFOV and HOOD_D set the hood for the lens. Change them if you use another one, for example 90° for the 2.8 mm lens.
Insert hole:PAD_HOLE_D is the insert hole size. Take it from the datasheet of the insert you buy.
Bill of materials
Camera kit, per camera (4×):
Item
Amazon search term
Qty
Approx. €
Approx. $
IMX415 8MP IP camera board, PoE, H.265, RTSP
“IMX415 8MP IP camera module board PoE”
1
60–90
70–105
M12 lens, 8MP-rated (2.8, 4 or 6 mm)
“M12 lens 8MP 4mm”
1
10–20
12–23
Polycarbonate or acrylic sheet, 2 mm
“polycarbonate sheet 2mm clear”
1 sheet (cuts 4 discs)
15
17
PG13.5 cable gland for RJ45
“PG13.5 waterproof RJ45 cable gland”
1
5
6
M12 breather vent
“M12 breather vent plug waterproof”
1
4
5
Brass heat-set insert 1/4"-20
“1/4-20 brass heat set insert”
1
4
5
Silicone gasket sheet, 1 mm
“silicone sheet 1mm gasket”
1
10
12
M3 × 16 screws, stainless
“M3x16 A2 screws”
8
8 (pack)
9
M3 × 8 screws, stainless
“M3x8 A2 screws”
2
included
included
M2.5 standoff kit
“M2.5 standoff kit”
1
10
12
Outdoor camera mast mount with ball head
“pole mount ball head 1/4 inch outdoor”
1
20
23
ASA filament, black, 1 kg
“ASA filament black”
~0.1 kg per camera
25 per kg
29 per kg
Network side (once, for all four):
Item
Amazon search term
Qty
Approx. €
Approx. $
8-port gigabit PoE switch, 802.3af/at, 120 W
“8 port gigabit PoE switch 120W”
1
100–140
115–160
Cat6 outdoor cable, shielded, UV-resistant
“Cat6 outdoor shielded UV cable meter”
~150 m
150–225
175–260
Ethernet surge protector, PoE-capable
“PoE ethernet surge protector”
4
80
92
Conduit and cable clips
“cable conduit outdoor”
set
40
46
RJ45 plugs, shielded, and a crimp tool
“RJ45 shielded Cat6 plugs”
1 set
30
35
Per camera the parts come to roughly €150–200 ($170–230). The whole system, with the network side, is about €1,000–1,400 ($1,150–1,600), not counting the computer.
Yes the upcoming version can track on just one feed. Deciding which feed to watch shouldn’t be too hard and can be automated.
But I think its fine with the sun. We’d tilt a bit more down to avoid looking at it. I would argue that’s the simpler and better solution. The trees on the closer side make the PoE solution even harder, because we’d need them to avoid the branches. Must you have a fixed solution? Don’t you prefer using a tall tripod?
